Use this procedure to view the LLDP local system information.
- Select LLDP.
- Select the Local System tab.
Local System Field Descriptions
Use the data in the following table to use the Local System tab.
| Name | Description |
| ChassisIdSubType | Indicates the encoding used to identify the local system chassis.
| ChassisId | Indicates the chassis ID of the local system. |
| SysName | Indicates local system name. |
| SysDesc | Indicates local system description. |
| SysCapSupported | Indicates the system capabilities supported on the local system. |
| SysCapEnabled | Indicates the system capabilities that are enabled on the local system. |
